How much would an iPhone 5s cost with a 30 dollar plan?
I have a $30 plan that has 200mb of data 150 anytime minutes, unlimited texting and free calling after 7pm. Would this be considered a medium tab or a small tab?
You could get either a small or a medium Tab with that plan. If you have any tab owing right now that will have to be paid in full before you can upgrade to a new phone, you can pay your full tab at the time of the upgrade or add it to your next bill.
As for the cost it's going to be around 275$ with the Tab M!
And your monthly charge will be $35 with Tab M. $30 plan + $5 tab fee.
So I could keep my old plan because when I called they said i would have to pay $5 more for 200 minutes, free calling at 5pm and unlimited texting but I only get 50mb of data. I don't want to pay an extra $5 more because the amount of data in it is useless!
Kevin Condo wrote:
So I could keep my old plan because when I called they said i would have to pay $5 more for 200 m...
I agree. Who want to pay more for less?
They are probably just trying to get up to the next plan. Yo may need more data they might be thinking.
You should be able to use your current $30 plan (150 min, 200mb) to use the Tab M. You will need to take $35 plan (200min, 50mb) if you are a new customer, but you are already with Koodo with $30 plan.
Yes but when I called koodo, they said I would have to switch my plan! Does it matter that I gotthe plan during a promotion?
Kevin Condo wrote:
Yes but when I called koodo, they said I would have to switch my plan! Does it matter that I gott...
It shouldn't. We're looking into this for you. Hopefully, we'll have an answer soon.
Thank you. I'll call koodo after, and see what they say. If I do get an iPhone, I will have to pay the extra $5 for the tab?
If you take tab M, yes (which I recommend because you'll get 100$ off). If you take tab S there's no tab charge!
Ah yes. Would my $30 plan be considered a medium tab
Hi Kevin, you can definitely keep your current plan 🙂 Enjoy this great phone! ________________________ If you see a good answer, give it a star.
Thank you I'll give my near by koodo a call.
