How do I return to koodo after I am home from travelling?
My iPhone still shows AT&T when I have returned to Canada. How do I get back to koodo as my carrier?
Open your network settings and find network selection and turn it to manual. Your phone should scan for networks and present you a list. Pick Koodo or Telus (preferably Koodo)... After you do this reset network selection to automatic.
Thx. Unfortunately already tried that and only AT&T comes up in the manual search...
Also be sure your iPhone isn't set to only use 2G Networks.
You can also try popping the sim out and waiting a few minutes before reinstalling it (make sure the phone is off when you do this)
Ok, did a network reset instead and it finally found Koodo. Problem resolved.
Yay!
