How do I keep track of my data usage add on for travelling
  • 4 March 2016
  • 7 replies
  • 36 views
(empty)
Hi Joanne,
This can be done in self serve under usage.
Hi Joanne,
Do they have a travel section for usage now, they didn't before you just had to keep track yourself on your phone?
Hi Joanne,
They may not, I never actually used the add-on so I may be totally wrong. I just assumed it would be added as an extra counter in the usage section for the month
Userlevel 3
As far as I know there is no seperate usage tracking for travel add ons. I was in Michigan a couple of weeks ago and had to keep track on my phone.
As far as I know there is no seperate usage tracking for travel add ons. I was in Michigan a coup...Ok thats what I thought, thanks for the verification Rick Tuttle... Any relation to the American chopper Tuttles?
Find an agreeable app on iTunes App store, and reset your counter to zero when you leave the country. Billing info for data while roaming may be subject to some delays, so a counter on the phone may be your safest bet.
sample: https://itunes.apple.com/us/app/my-data-manager-track-your/id477865384?mt=8
Thanks everyone for the replies. I guess I will just try and keep track of it myself.
