how do I check voicemail on my cell phone from another phone?
  • 29 June 2018
  • 1 reply
  • 3352 views
I don't have access to my cell phone right now and need to check for messages. CAn I do that from another phone and if so, how?
1 reply
Yes. Dial your number. When yourvoicemail message starts, press *, and enter your voicemail PIN. You will then be taken to the VM system prompts. See https://www.koodomobile.com/help/voic...
