How do I check my voicemail from my Koodo Home Phone from another phone such as my cell?
Guide states:
You can retrieve voicemail messages from a phone not connected to the
WF721.
1. Dial the number of your WF721.
2. When you hear the voicemail greeting begin, press the “*” key
3. Enter your password and follow the prompts to listen to and manage your voicemail messages.
?  What's the number to dial from my WF Unit?
1 reply
You dial the phone number of the voicemail in which you want to connect to. If you want to access your whp voicemail then you call that number.
