How can I get sound on my iPhone 4 ? I can't hear anything without turning on my speaker ..... Help
HEY there I take it that your having audio issues on phone calls? go into settings, general, reset, and reset network settings, this should help, if not, this maybe a mic issue and you will need to get in contact with apple for warranty inquiries
HippieLongstocking wrote:
HEY there I take it that your having audio issues on phone calls? go into settings, general, re...
Tks , I tried this and still can't hear anyone on other end without turning on speaker
click on this link http://support.apple.com/kb/ts5196 if none of those optiosn help connect phone to itunes, back it up and then restore, if none if this helps call apple 1-800-263-3394
