Help! Texting other Iphones without data
Why can't I receive text messages from other Iphones without a wireless connect/iondata/iMessage. Shouldn't I be able to text normally? I can send texts out but I won't receive them until I am connected to the Internet. I want to text normally without setting my data back up.
Userlevel 4
Is this always the case or did this crop up recently? You may want to check out your settings
Right after I got my data blocked it occurred :c I only have 50mb on my plan and I don't want to go over it by accident so I simply just shut it down.
You might find buying a little more data the best option. You would then be using your phone as designed, and won't need to apply these work-arounds.
You may find this thread helpful : https://c.getsatisfaction.com/koodo/topics/help_iphone_texts_vs_imessage
What happens if you send yourself a text while you are away from a wifi connection? This should force your text connection to look for the phone network (not data).
If you have a data block on your phone, iMessages from your friends will not reach you unless they have turned on the Settings > Messages > Send as SMS on their phone. If you do not wish to have a data plan on your phone, it is best to turn off Messages altogether. Also make sure they are sending Messages to your phone number, and not your Apple ID.
Hey there Angie. My best solution is to close iMessage altogether because like that you won't have any further complications. http://www.idownloadblog.com/2014/05/14/how-to-remove-a-phone-number-from-imessage/
