HELP. NEED AN URGENT ANWSER
Hi, I have a question. I want to buy an iPhone 6 but not go under contract. Can I buy the phone straight up for its regular price and choose any plan I want because I have very bad credit with credit checks?
Hi there... Even if you are willing to pay for the phone up front, you will need to go under a credit check, and then you will see if you are eligible for the services or not... If you are, Bingo, you can buy it and choose any plan...
You're better off buying an unlocked one from the Apple store. That way if you don't get approved with Koodo you can try the other carriers.
Hi Chantal,
With any of the carriers, you will need to pass a credit check for a monthly subscription. Do as Jonathan said, and buy an unlocked version from an Apple Store. From there, you can sign up on a pre-paid plan with the carrier of your choice and pick which ever ones have the best plan for you!
On a side note, if you have very bad credit already, I would suggest avoiding credit checks as often as possible, so I would strongly recommend against going to each provider in hopes of passing one of their credit checks.
