help
why does my phone indicates CRITICAL. Also why does it say No connection when I want to open my facebook page. Why can't I get the weather incon to open
It sounds like you're having reception issues/a lack of connections. Not sure where Critical is showing up however. a few things to try. 1. if you should be connected to Wifi does it say 3G or show the Wifi signal at the top of the screen. 2. Go to settings, then general, then Cellular or Network and make sure 3G is enabled. 3. Hold both the power and home buttons down until you see the apple logo appear. Did any of these help?
Userlevel 3
Also pull the battery and remove your SIM card. It often helps resetting the phone.
Tough to pull a battery on an iPhone 😉
Critical
