Forwarding calls to a US number (while using a US SIM card)
I'm travelling to the US and I'm using a Roam Mobility SIM card, which gives me a US number and talk/text/data on the T-mobile network. But in case I get any calls during the week, I was thinking about forwarding them to my US number. Does anyone know how much that would cost, or if it is even possible? Thanks!
Should be possible, but I'm pretty sure you will be charged long distance for any forwarded minutes, just as if you were calling the US from your cell.
Thanks Timo - so if I understand, it would be $0.35 per minute for PPU Call Forwaring, and then $2 to add Long Distance Saver, and $0.05 per minute for each call I receive. right?
As I understand it, yes.
