For some reason my phone won't turn on , it's on charge but nothing is happening.
Hi Amber,
Try using a different charger, different wall outlet/usb port, etc.
Have you tried holding down the power button and see if it turns on? Is the screen black and nothing else appears?
If the battery completely discharged, it may take up to half an hour of charging before the phone will even turn on.
Depending on the phone model (and I know ziltch about iPhones), hold power and either volume up or volume down for 15 seconds (whether it's volume up or volume down will vary per handset).
