facetime not working and texting messages operations
  • 30 September 2020
  • 3 replies
  • 49 views
FaceTime not functioning and texting no longer works properly on iphone
Is this regardless of what network you're connected to? Both cellular and dif WiFi networks? Is system date and time set to automatic?
Try restarting your phone. Then try resetting network settings. This will erase all saved WiFi and Bluetooth connections.
What happens when you turn imessage off.  Are you able to send Green text messages?
when you are saying texting doesn’t work, is it all texting or only blue messages (iMessage)
