email address of my mobile phone device does not work
i need to get notified for my university for their watchlist and although i use my [i]10-digit phone number@msg.koodomobile.com example: (0001234567@msg.koodomobile.com) it still does not notify me when there is something new posted. i am on prepaid, this is really important and i may have to switch phone companies if this is not fixed. it is not a problem with my university since my other friends who are with other phone carriers receive these messages
Try @msg.telus.com
Try [i]10-digit-number@msg.telus.com - that works for me (also on prepaid).
Interestingly, [i]10-digit-number@msg.koodomobile.com also works for me, but shows up as MMS instead of a normal SMS like the one I sent to msg.telus.com.
Ray wrote:
Interestingly, [i]10-digit-number@msg.koodomobile.com also works for me, but shows up as...
Yes, the Telus gateway sends as SMS, and Koodo's gateway as MMS.
Koodo didn't work for me...and I do have data and MMS
Large emails may not send through this means. Are the notifications the university sends you short text-sized ones, or longer emails? If the latter, possibly setting up an email client on your phone is the better choice.
