does siri work only with data? or can it work with wifi?
Siri will work with both your network data connection and your WiFi connection.
As Alcide said yes it should work on both. However a lot of problems were reported when siri is used over wifi which is not the case when it is over a 3 G connection
So when are you buying the iPhone?
8 questions on buying it !!!so far!!!, still need to wait for some others !!
Dudes doing his research. Lol
Thx MM.
