Data only plan for iPhone
Hello! 1. Can I use my unlocked iPhone with only data plan from koodo? 2. Can I use my unlocked iPhone with pre-paid data plan/booster only? 3. I only need about 500MB of data per month and no minutes/texts etc. for my unlocked iPhone, what would be the minimum monthly cost? Thanks in advance.
1) No. Monthly plans include unlimited texts, voicemail, call display, and various mins 2) No. Prepaid base plan includes unlimited texting, voicemail, and call display. Data Boosters can be added 3) Monthly - $44 minus 10% since your are bringing your own device Prepaid - $30 based on buying the 1GB data booster and using it over 2 months
Thanks Dennis. Do you mean that I can prepay $30, get 1GB use it over 2 monts? I would consider this my cheapest option ($15 per month for what I need). Do I need to keep prepaying every month to keep it going at $15/month?
Yuriy Morayko wrote:
Thanks Dennis. Do you mean that I can prepay $30, get 1GB use it over 2 monts? I would consider t...
You get the $15 base plan. Then you add data boosters in 1GB ($30) increments. So if you only use 500MB ($30/2 = $15) + $15 base plan = $30 per month http://koodomobile.com/en/on/plansandboosters.shtml
It means that I have to buy "base plan" can't just buy a booster for &30/2 months.
Correct
Can I buy only booster on prepaid?
Yes. Boosters are only for prepaid
I may have read it wrong but if you're asking if you can get just a booster. Then no you will need to keep a baseplan active. If that's not what you meant then ignore this comment. 😛
Daniel. You nailed it. Thanks.
