Data doesn't work
I changed my plan yesterday to the 35$ one with 1GB of shock-free data. When I try to enable it on my iPhone 6, it doesn't work. I activated Cellular Data and I even activated it for certain apps such as Safari and it says "no internet connection". What should I do?
Try turning off and on airplane mode. If that doesnt work turn off your phone and remove your SIM card and your battery (if possible). Wait a minute and then put everything back together and then it on. This shoukd reset your SIM and have it all back and working!
You can also reset network settings if that doesn't work. Bare in mind that it will delete all saved Wi-Fi and Bluetooth connections.
Did you ever have a data block on the account?
Hello Bianca,
Have you tried the above steps? Do you still need help?
