data and international calls
I just bought my sim card and I can call and everything, I asked for a $60 plan with 1GB but he data does not work, how long should I wait for it to works? or is it some problen with it? and I want to know if incoming international calls have more charges.
Did you set your apn? Check here: Http://koo.do/unlockedphone
Try setting your APN sp.koodo.com for data and follow below for MMS http://mobilemasters.koodomobile.com/the-comprehensive-guide-for-bringing-your-unlocked-device-to-koodo/
Is it an unlocked phone? Plug it into iTunes to update the carrier settings.There are no additional charges for incoming international calls.
