Connect Satelit Problem
hello ! I'm a new user of koodo, just 2 weeks. I've problem, the connexion is not found by phone. The koodo account say no problem, please tchek the problem and whrite me what i will do. Thanks
Hi Amaury,
Please remember we are all consumers just like you and have no access to your account.
The best way to diagnose any network connectivity issue is by turning the phone off and taking the battery as well as the SIM card out of the phone and let it sit for a few minutes. Re-assemble the phone and see if it's now working.
If it is still not working then check the APN settings of your phone by following the instructions at this link:
http://help.koodomobile.com/plans-add-ons-data-and-other-services/data-basics/how-do-i-setup-data-on...
Hope this helps!
Thanks, i don't anderstand the service is just consumer.. I will try your technik..
Hi Amaury, were you able to reach our technical support? You can contact us at 1-866-995-6636 from another phone, option #6. Thank you!
