Charged $44 in call forward Even when Add on was active
  • 20 March 2017
  • 9 replies
  • 21 views
Userlevel 2
Userlevel 2
I did had a $3 add on but still was charged for forwarding more than 40$ not sure why. My call was forwarded to a local Canadian number. I will attach a copy below of bill
Userlevel 2
[img]https://d1qy7qyune0vt1.cloudfront.net/koodo-en/attachment/RackMultipart20170320-65553-jdg7rp...It was forwarded to a toll free Canadian Number
[img]https://d1qy7qyune0vt1.cloudfront.net/koodo-en/attachment/RackMultipart20170320-65553-jdg7rp...$3/month is just to be able to use call forwarding. You get charged $0.50/min on call forwarding calls.
[img]https://d1qy7qyune0vt1.cloudfront.net/koodo-en/attachment/RackMultipart20170320-65553-jdg7rp...What happens when you use call forwarding on your phone app without the add-on?
Hi ABH - looking at your account, you have a $3 add-on, but it's for the international long distance saver, which gives you a discounted rate on all long distance calls. You in fact don't have call forwarding as an add-on.
@Allan - the $0.50/min charge is the pay-per-use rate. Customers that have the $3 add-on don't get charged an additional rate.
Userlevel 2
@Ranjan - I did *21*18007014497# and hit SEND and did receive a message that enabled call forward. Did I miss a step which could have minimized the billing?
@Ranjan - I did *21*18007014497# and hit SEND and did receive a message that enabled call ...That's the correct procedure to forward calls, but since you don't have the add-on you were charged the pay-per-use rate of $0.50/min. Once you add-on the monthly feature for $3, you'll still forward using that method, but you won't be charged pay-per-use.
Does that help?
Userlevel 2
@Ranjan - I did *21*18007014497# and hit SEND and did receive a message that enabled call ...I added $3 add-on, thinking that feature. Could you guide how to add the addon you talking about?
@Ranjan - I did *21*18007014497# and hit SEND and did receive a message that enabled call ...Sure thing.
When you log into your self serve account, go to 'View Rate Plan'.
Once there, the first line under 'Change My Plan' should be 'Your monthly add-ons', and to the right of that it should say 'Manage' - click on manage.
From there, you can remove any add-ons you don't need (i.e. if you no longer need the $3 Intl. LD Saver feature), and also choose any new add-ons from the list below - select $3 Call Forwarding.
Once selected, you'll be able to review your list of add-ons and confirm your selection.
