changing sim card problem
  • 2 April 2015
  • 673 views
I just changed my cellphone, so i needed another sim card, how can i activate this chip maintaining the same phone number and account from the previous sim card?
Best answer by Sophia 2 April 2015, 23:54
You can do that in self service, Victor. Just change the SIM card number to your new one, and everything will be preserved 🙂
Ineed help doing this do I call in
@Shandon : are you a prepaid or postpaid customer? if you had a spare sim you could change your sim in your self service https://www.koodomobile.com/help/koodo-sim-support
Does your new phone need a nano sim card and your current/old sim card is bigger than that and doesn't fit? Because otherwise you can just put in your current sim card, use your phone like normal, and not transfer to your new one.
