Feedback
changing from virgin to koodo | Koodo Community
  • 28 August 2021
  • 1 reply
  • 17 views
If I get a SIM card from Koodo, does that mean I have to give up my old cell number
1 reply
You can port your number into Koodo.
You order a Koodo SIM > once you received SIM, create self serve and processing port your number.    Don't cancel your Virgin account since you need a tube line/account to port.
More info,:
https://www.koodomobile.com/en/help/moving-your-number-koodo?search_api_views_article_search_fulltext=Porting
