Changed plan
  • 7 April 2019
  • 2 replies
  • 78 views
I’ve used all my data on my old plan, I just changed it tonight because I would like more for the following months, my question is, does it restart now or on the 8th of April when my old plan would reset?
Your new plan should start pretty much immediately, or within a day. Your bill will show the pro-rated amounts for each plan / portion of month.
The plan change will happen right away.
Make sure you have unlimited minutes when you change your plan in the middle of a cycle. Your total minutes would be prorated and sometimes customers might be charged overage (if you had a limited number of minutes (500) and didn't pay attention to it)
