Cellular Data Problem!
My phone is a telus iphone but I'm using it with a koodo SIM card. Anyway, in cellular->use cellular data for, it only shows FaceTime and Passbook. It is supposed to show all my apps! Now I'm using so much data! What can I do?
Have you updated the carrier settings through iTunes?
How do you do that?
Userlevel 2
Plug your iPhone into a computer with the latest version of iTunes. You should get a pop up notifying you about updating carrier settings. Click the confirmation button and it will update the phone with the proper settings.
Yeah, I don't have an update.
Userlevel 2
Contact Apple then. There's very little Koodo can do about this.
Userlevel 2
Maybe those are the only 2 apps that have used mobile data.
No. It's using data from my apps like instagram, mail, iTunes Store, etc.
