Can't call out on US roaming with AT&T.
  • 29 August 2015
  • 11 views
Can't call out on us roaming with AT&T.
Is it all numbers or just Canadian ones?
You can try dialing 468 then waiting 3 seconds followed by the number you wish to reach.
U.S. And Canada. First worked when I crossed the border. But it wasn't AT&T
468 plus delay is a code to jump to another level of AT&T service. Check out your network connections settings to see who is connecting to you.
468 delay has not worked. What do you mean who is connecting to Me?
Hi Colleen, are you able to use your phone now? Keep us posted! Thanks!
