Can't call Canada from uk with add on plan
I purchased a $40 add for talk, text and data while we travel though England. I have tried to contact my bank though and even using the international dial out code it won't connect and says unavailable. can anyone please tell me why this may be? I can't even call koodo to get them to take a look and now I am quite frustrated with the fact I have paid for something that isn't working for me.
Lot into your self serve account and make sure you add international voice roaming free add on Reboot the phone and try again
You can always call Koodo via Skype if the above solution doesn't work! It's a free call
Thanks! I will try that because nothing is really working now that we're trying other parts of the plan. The self serve app isn't even loading on my phone currently.
Also where are you and what phone do you have
iPhone 6, London England.
Before you call in. Have you tried adding the Add-on I suggested? *
Can you connect to wi-fi anywhere to try checking via the self-serve app as Chad suggested?
I have tried the wifi with no success, turning my phone off and on just to ensure it wasn't a connection issue, and am now on hold with koodo as it isn't working yet. Thanks for your help though!
@ Sami Turn your phone on airplane mode and back. We made a slight tweak on your service that should help.
