Bluetooth connection notifications are silent.
Hello, I am new user of Samsung Galaxy. On my few first days the phone connecting to Bluetooth made whistling, but now it keeps silent (but connecting successfully). The other notification (text message as example) makes whistling. I do not know what I did occasionally and why the Bluetooth connection notifications keep silent. Please help.
Thanks,
You can change your notification sounds in the Settings. It should be in either a "Notification" section or "Sound" section. There you should be able to control what notification sound plays when certain notifications and actions are performed.
Userlevel 2
With Samsung Galaxy go to "setting" then "Sound" &, check both of following 1- Volume: Hit and look for notifications bar. Move it right to increase or vice versa. 2- Go back and scroll to default notifications and ensure it is not set to 'silent"
Thanks, fixed!
