ATTENTION ALL PHONE EXPERTS: HELP ME.
Can I buy an iphone off of kijiji that was a replacement phone with a 90 day warranty and still have it work, or because it is just a replacement will it stop working in 90 days? HELP. This may be a stupid question but I've confused myself lol
If it's compatible with Koodo's frequencies then it will work if it's unlocked or a koodo or telus phone. However keep in mind that you should make sure that the phone works with a SIM Card, also make sure the phone isn't flagged as stolen with the provider it's from.
The phone will work fine (as long as its a Koodo/Telus phone or is unlocked). It's just after 90 days if there's any problems with it you will have to pay to have it repaired.
After you buy it from kijiji dont expect that 90 warranty to still be good. Sounds like a warranty from the iphone's original carrier
Dennis wrote:
After you buy it from kijiji dont expect that 90 warranty to still be good. Sounds like a warran...
Just be careful buying phones on sites like kijiji and make sure they are good quality. As long as it is a Koodo/Telus phone, it should work. You can always unlock if you want.
An replacement phone won't break after 90 days. It will still work! Also, during those 90 days, you can get it exchanged at an Apple Store if there's a problem with it. Even if it's bought from Kijiji.
