Are my canada wide minutes being used on incoming calls?
Best answer by Ahmad 4 July 2015, 13:09
If you're on prepaid and don't have "Unlimited Canada-wide Incoming Calls" in your baseplan, then yes your canada-wide minutes from your booster will be used for incoming calls unless you have unlimited evenings and weekends and receive calls within that time frame.
If you're not on prepaid, then if you don't have unlimited incoming calls included in your plan (if its an old plan) or add-on, all incoming calls will use your daytime/anytime minutes unless you receive your calls within your evening and weekend calling period.
1 reply
