Am going to all inclusive resort cancun, I'm assuming they have wi fi. What changes do I make to my i phone. And what else should I not do.
Best answer by Jonathan I 23 February 2014, 23:48
Make sure you have at the very least data turned off and leave it off. Calls you can decline, texts you can't, so if you're paranoid, then enable Airplane mode the entire time and turn on WiFi when needed. An alternative is to take out your SIM card that way there's no way you can accidentally do something.
1 reply
