Air time overage problems
I am being charged airtime even though I've only used up 60 min. of my 200 min. plan. I've been charged $2.00 for 4min of calling? Why is this happening
Userlevel 4
USA call?
Danny wrote:
USA call?
I live 2 hours away from the US border and the call was 100ft away from me
Userlevel 4
Danny wrote:
USA call?
I meant "call to a USA number"?
Check your usage in self-serve. Do you live/travel near the US border? Your phone may be locking on to a stronger US signal and roaming may be kicking in even though you are calling in Canada.
If this is the case, Koodo normally will reverse the charges if you call *611. You can then set up your "mobile networks" to log onto Koodo only, and ignore the automatic setting.
Userlevel 4
BobTheElectrician wrote:
Check your usage in self-serve. Do you live/travel near the US border? Your phone may be locking ...
The problem with that theory is that it would cost more than $4 for 2 mins roaming without a plan:
http://help.koodomobile.com/my-bill/charges-explained/long-distance-and-roaming-charges
i live 2 hours away from the US border and  the call was 100ft away from me
Did you just start your service or recently change your plan?
It's probably proration, like Chad said. Check page 3 of your bill. Do you see 2 lines in the date section? It will show the activation date to your cycle date and then the following month under it. That means you only had a small amount of minutes to use during the first month.
How do I get my money back if I was prorated unknowingly?
Can you start your own post using this link?
https://community.koodomobile.com/koodo/topics/new
And we need more info about your issue.
What plan do you have and when did you change your plan?
"... if I was prorated unknowingly?"
It happens when you change your plan in mid billing cycle or when you first sign up.
