AB 1 GB $45 UL minutes plan
  • 18 May 2015
  • 1 reply
  • 11 views
Why when I login into my self serve account and go to change my plan would I not be able to see the $45 plan that is advertised for Alberta (1 GB & UL minutes). I am on BYOD with iPhone. Is it for new customers only?
Best answer by Mayumi 18 May 2015, 03:45
You will need to call Koodo to switch to this plan. *611 from your phone. They won't charge you for this since you can't do it through self serve.
1 reply
