2 koodo phones? iphone question!
Can you have two tabs? Is it possible to open a 2nd phone line and have a 2nd tab to give a family member that phone? also does the iphone 4 HAVE to go on an iphone plan?
Hi James, Yes, you can have two lines under one account, to benefit from the free unlimited family calling, and as such you can have two Tabs 🙂 You don't need an iPhone plan, in fact most of us would try to talk you out of that 😃 Just get the iPhone on a Tab is the cheapest and most flexible option!
Sophia wrote:
Hi James, Yes, you can have two lines under one account, to benefit from the free unlimited fa...
Also, you can't be on the Spending Cap program if you want a 2nd line. Spending Cap accounts are restricted to 1 active line.
