I don't know. Can we get more details? What phone do you have? What exactly is happening when you try to answer? Can you make calls?
No.i cant make calls i toke out my batter an sim card still nothing
So you can't make calls or receive calls. Do you show as having a signal. What phone do you have? Is it only phone calls? Can you text or use data? Are you sure you are up to date with your bill payments?
Are you on prepaid or postpaid? Do you still have minutes if you're on prepaid?
Login to the community
or
