Not planned
Way to fix cracked screens
Coming up with a inexpensive way to fix cracked screen without having to buy a new phone. Like what is available for iphone users
I went the other day on this forum where they explained how to fix cracked Android phone screens:http://forum.xda-developers.com/showthread.php?t=733596 - it may be useful for posters that have android cracked screens.
MatB wrote:
I went the other day on this forum where they explained how to fix cracked Android phone screens:...
That is for an HTC Aria tho Mat - different phones have a whacky different time changing out components. I find http://www.ifixit.com/Guide tends to be a bit more... comprehensive. Taken stuff apart using their guides, very straight forward and easy to explain how various elements work. For example a phone which uses an OLED screen has a totally different method of getting the digitizer removed from an LCD screen on say anything non Samsung. Even different phones from the same manufacturer are totally different beasts to change out the digitizer.
Hey Meghan! I went on google and searched a bit for you and found that there are lots of places you can go to get your screen fixed, it just depends on where you live. If your phone is under warranty, you can take it to the Apple store and they will fix it, but it's not cheap. Hope this helped! 🙂
