Proposed
Visual voicemail for pixel
  • 13 December 2018
  • 4 replies
  • 2495 views
Would love the option to add visual voicemail to my pixel.
hi,
Someone mentioned that you can add visual voicemail add-on for iphone and Visual voicemail option would show up in the pixel.
I haven't tried it myself, but you can test it. If it didn't work you can remove it (in the worst case you would be charged for 1 day $2/30=$0.07 (7cents)).
Update: this worked. You were right! I added the iphone addon and waited 5 minutes, turned my phone on and off and I now have visual voicemail. Thanks!
Yep it works. I use it on my OnePlus 5T as well. I don't get a lot of voicemail so I may remove the add-on at some point--mostly I wanted to try it out to see what all the fuss was about. 🙂
Works for my Pixel 2 XL
