Implemented
US roaming block for customeres in boader towns.
not just for texting but for calls and data so many instances where people are getting charged for roaming in canada because thety live in a boader town usally told to manually select networks, but this is annoying as you maybe on a call and you don't know if your roaming or not, and who thinks to look down at thier phone in a middle of a call to make sure they arent roaming. so please koodo, can u get a uUS roaming block not just for sms but for everything 🙂 there will be less disputes for accidental roamaing 😉
yes please
I believe this currently works for pre-paid (since pre-paid aren't able to go to the US) ... so theoretically it seems like it's something doable, though other carriers work the same way. So while I agree it would be good to have, I'm not sure they can unless you're using a non-Smartphone.
John Burke wrote:
I believe this currently works for pre-paid (since pre-paid aren't able to go to the US) ... so t...
i was told telus does it .but its hard to say
Userlevel 4
Set your phone to Manular network selection. This is not something you do per call, this is a general option in any good phone. The phone will then only connect to the network you have chosen manually.
Daniel AJ wrote:
Set your phone to Manular network selection. This is not something you do per call, this is a gen...
im aware of that but sometimes doesnt always work.
Userlevel 4
Haha, that should have read "manual". But "Manular" is a nice creation, too. 🙂
this always happens when i'm visiting girlfriends parents, literally other side of the river is the US, i get the txt msgs when i get on AT&T's towers, but if my phone rang, i probably wouldn't see it before i answered 😞
