Smaller plan
Make a plan with 50mins, 50 mb of data and unlimited messaging for $25 a month
Userlevel 2
If you get the 29 plan and have your own device it has another 10% off so only 26 a month
Might as well go prepaid. Or do you want to get a subsidized device with this plan too? Then the $29 is better value. The extra 4 bucks a month would essentially be the cost of a Moto G on Tab S.
As Jonathan said, prepaid is the way to go, Boaz! 50 minutes: $2.50 (based on largest booster) 50 MB: $1.50 (again, based on largest booster) Plan: $13.50 (based on automatic top up) Total: [b]$17.50 and includes unlimited worldwide messaging 🙂 Can't get it any better than that 😃 On postpaid it would cost you $33.50 at least ($29 plan + $7.50 for data) or $30.60 ($34 plan) with the 10% discount applied. Only advantage to those postpaid plans is they include unlimited after 5pm and weekend calling... to be fair 🙂
Sophia wrote:
As Jonathan said, prepaid is the way to go, Boaz! 50 minutes: $2.50 (based on largest booster)...
Plus it's Canada-wide by default. Also the Moto G was just removed from prepaid (but it was only an example).
The idea is not planned, but I would encourage you to visit our Prepaid page. This will most likely suit your need: http://koodomobile.com/en/on/prepaid.shtml
Thanks!
