Proposed
open wireless home phone back cover
  • 11 March 2020
  • 8 replies
  • 91 views
Is there a video for that?
You would need to search for that on Google.  Search for the Make and model and then do a video search
why they make it so difficult to open. it is terrible .
Which model do you have? We might be able to help if you cant figure it out yourself or through google.
zte wf723ca
THis is what googling got me
Yes, that is helpful. But, why the instruction is so misleading.
That is a good question.  I would blame the manufacturer for that since it is their instructions
On occasion I have bought products from off-shore manufactures and found that the instructions can be confusing and at times hilarious. Sometimes things get lost in interpretations. But Dennis found the answer for you.
