Proposed
koodo
  • 30 November 2018
  • 3 replies
  • 584 views
how do i get call fordarding active
You can add the call forwarding add on to your account via self serve for $3 a month. You can find instructions on how to turn call forwarding on here:
https://www.koodomobile.com/help/call-forwarding
OR you can use your phone app, there should be call forwarding settings in there too
Definitely go for the monthly plan. If you do it piecemeal, you'll bust your budget in no time.
