Implemented
international plan
Is there an international voice plan for Koodo?
I think Koodo has recently added roaming packages for Mexico and another country that I can't recall right now but that's it, besides the U.S. I'm not saying it won't work; you can enable international voice roaming as long as you're not on spending limit program, but the rates start at $1.50 or $2.50/min and .60/text plus $5/MB for data. You're better off unlocking your phone (unless it's a Nexus device) and using a local provider in the country you're visiting. The rates will probably be cheaper.
Jonathan I wrote:
I think Koodo has recently added roaming packages for Mexico and another country that I can't rec...
It's actually Mexico and the Carribean (which covers all Carribean countries except the Bahamas). The U.S. Virgin Islands are covered by the U.S. package and not the Carribean one though.
