Not planned
Improve/Replace Koodos Web A.I. Suggestions Interface
Although initially amusing and often quotable your A.I. Suggestions are typically so off topic that for me, a regular poser of questions and ideas. it soon grows tedious and tiresome. Particularly aggrevating is the "Ease up on the all caps in you title, it looks like you're shouting." message, when, in fact I capped 1 of 10 words only because it was capped on the web page I was referencing. Here's my suggestion (no A.I. required). "Fix your A.I. Web Interface. It makes you look like you are stupid."
I guess it was done that way to catch other posters attention!
Well, I just thought it should be intelligent enough to differentiate between a ligitimate use of caps and an obvious overuse that would indicate yelling. If it can't then it's really just A.S. Artificially Stupid. Better to ditch it and have the moderator comment if an individual abuses the Title format.
