Implemented
Data Usage Texts
I know some carriers already do this, and I think its a great idea... How about sending out a text message update of customer's data usage? I know I go over my Data Saver amount sometimes, and think it would be really useful to know how much I've been using so I don't end up with a huge bill.
You receive a text from Koodo if you used 75% of your monthly data, as a warning, I believe. You can also check your data usage on Self Serve. Just get the application, and check your data every once in a while and see for yourself.
In case you didn't quite get what John was referring to....the "app" in the itunes store or android market or blackberry app world is called Koodo Self Serve. It's free.
