Proposed
battery
  • 9 August 2021
  • 2 replies
  • 21 views
How to fix draining battery on Motorola Moto e
You can check what's causing a battery drain in your phone settings or use accubattery to check it out and remove apps that are high drain accordingly.
It should also generally tell you If your phone battery health is good or not.
You can try to enable adaptive battery and battery optimization to see if that will help stop certain apps from draining your battery even more. https://support.google.com/pixelphone/answer/7015477?hl=en
