Proposed
Activate VoLTE on Samsung Phones
  • 18 May 2019
  • 723 views
Hi Dear Ones...
Here I wish to Share an Idea... Which helps you to Activate VoLTE on Samsung Phones.
This Method I Have Used in many Phones.
Some Samsung Phone Variants Has This VoLTE Function, But Phone Actually Won't Connect to VoLTE.
Mostly After a Software Upgrade or Reset.
For Them, This Steps will help.
Follow This Steps to Activate / Enable VoLTE in Samsung 4G Phones
  • Dial *#272* 15 Digit IMEI # ( *#272*000000000000000# – Replace ” 0 ” With Your IMEI )
  • Select INS and Tap Install
  • Phone Will Restart Automatically
  • VoLTE Will Work After The Successful Reboot
if you want to Know More About This, then Visit This Page: Enable VoLTE on Samsung.
Was this about the CSC code change? This only work if the model is a Canadian model. Also customers need to have the VoLTE access in their account.
I tried this on few phones which imported from Dubai.
I flashed the INS Firmware.
The Same Will Work on Every Samsung.
Keep in Mind, if a Phone ( ex note 9 )
Has VoLTE Facility by default.
but, The Phone You Received from an Operator or from a particular country not Support VoLTE,
So its By Default Disabled.
We are actually activating this.
in Simple Words.
if the phone actually has the facility, but some reason VoLTE is not working, then only this method works...
Can you provide snapshots of what you did?
To Activate VoLTE on Samsung Phone
I just Followed the Exact Steps on the Website.
Simply Go Through the above URL,
There is a Picture,
When Dialing The Secret Code, That Screen Comes.
There I selected INS.
INS for India.
for Canada its Different.
Can You Find the Firmware Country Code?
There is a Picture,
INS for India.
Are you a current Koodo customer? Can you post the snapshots with Koodo network?
