What model Q10 does Koodo carry?
  • 18 August 2013
  • 251 views
I know there's like 4 models of the Q10 out there, which one does Koodo carry? The SQN100-1, -2, -3, -5? I want to buy an unlocked version on EBay, not sure which one to get to make it work on Koodo. Thanks!
Assuming it's the same as TELUS, which it should be, I assume it's the SQN100-1 since it fits the bill. See below for details: →From TELUS' website: BlackBerryQ10: LTE: 700MHz (Band 17) / 850MHz (Band 5) / 1900MHz (Band 2) / AWS (Band 4) HSPA: 2100MHz (Band I) / 1900MHz (Band II) / 850MHz (Band V) GSM: 850MHz / 900MHz / 1800MHz / 1900MHz →Information gathered online through various sources: BlackBerry Q10 smartphone SQN100-1: Quad band LTE 2,5,4,17 Tri Band HSPA+/UMTS 1, 2, 5/6 Quad band GSM/GPRS/EDGE (850/900/1800/1900 MHz) BlackBerry Q10 smartphone SQN100-2: Dual band LTE 13, 4 Dual band CDMA 1xRTT/EVDO Rev A (800/1900 MHz) Quad Band UMTS 1, 2, 5/6, 8 BlackBerry Q10 smartphone SQN100-3: Penta Band LTE 3, 5, 7, 8, 20 Quad band HSPA+/UMTS 1, 2, 5/6, 8 Quad band GSM/GPRS/EDGE (850/900/1800 MHz) BlackBerry Q10 smartphone SQN100-4: Single-band LTE support: LTE 1900 MHz band Dual-band CDMA support: Cell band 800, PCS 1900 MHz Quad-band GSM support: GSM 850, GSM 900, DCS 1800, PCS 1900 MHz Quad-band UMTS support: UMTS 800/ UMTS 850, UMTS 900, UMTS 1900, UMTS 2100 MHz BlackBerry Q10 smartphone SQN100-5: Quad Band LTE 2, 5, 4, 17 Quad band HSPA+/UMTS 1, 2, 4, 5/6 Quad band GSM/GPRS/EDGE (850/900/1800/1900 MHz)
Ah I see. So if I buy the SQN100-1 unlocked from EBay, I should have no issues using it on Koodo's network right?
Ah I see. So if I buy the SQN100-1 unlocked from EBay, I should have no issues using it on Koodo'...If it's unlocked, it should work just fine.
i just bought a BlackBerry q10 gsm from verizon ... that will work with koodoo !?? 😮
its written : worldwide unlocked ...
It should work on HSPA (3G) but not LTE.
