What kind of phones will work with Kodoo sim and network ?
  • 4 September 2017
  • 2 replies
  • 36 views
(empty)
Hi jayesh shah these are the frequencies Koodo is currently using
4G LTE and LTE Advanced:
2100 MHz downlink and 1700 MHz uplink (AWS)
1900 MHz
700 MHz
850 MHz
WCDMA :850 MHz and 1900 MHz (UMTS)
Any size SIM Card slot as Koodo has tri cut perforated SIM cards that you punch out to fit all 3 sizes.
If you are shopping for phones, you can cross-check with
www.willmyphonework.net
