Using a Rogers Torch 9800 on Koodo Netwok
If I get a Blackberry Torch 9800 from Rogers, would I be able to unlock it and use my Koodo SIM card with it? Basically what I'm asking is, will i be able to do all the things I am able to do now on my android device ex: use my data or unlimited texting?
Hi Ryan, no need to ask the same question over and over. It's been answered. Check your profile and you'll see. 🙂 http://community.koodomobile.com/people/ryan_blanchard_6397794
Chad Burr wrote:
Hi Ryan, no need to ask the same question over and over. It's been answered. Check your profil...
I'm sorry ... I can't find any answer by following that link. Will the Torch 9800 work on the Koodo system? Will it access data? Will it access wi-fi? Thanks.
Is it just the 9800 or is there more to the model number?
Just 9800, so far as I see in my Rogers account.
According to gsmarena.com, It uses the umts 850/1900 bands, so you should be fine. Make sure you specify older style BlackBerry when you choose a plan so that you'll have the proper provisioning on your account.
Oh sorry! Im new here and never knew! Thanks for the heads up!
No problem, welcome!
