Trouble with photo texts
I am unable to send photos or open photos sent to me through text messaging.
What phone do you have? What plan/add ons do you have?
I have a Blackberry Torch and I do have a data plan.
Is your data off/disable? It seens to be on in order to send /receive picture messages. Also, I see you have a BlackBerry. With Blackberry, along with data having to be enabled you also need to actually have a data plan (whether it's included in your plan or you have a Blackberry add-on) in order to send/receive pic messages
Ahmad wrote:
Is your data off/disable? It seens to be on in order to send /receive picture messages. Also, ...
Go to options->device->advanced system settings->tcp ip and make sure the apn is enabled and set to bb.koodo.com Go to options->device->advanced system settings->host routing table, press the menu button and click register now. Reboot the phone. Test again. If it still doesn't work, call tech support from another phone. 1-866-995-6636, option 6.
