Plan chng lose APN access?
I have a Q5... was considering changing plans but it says one of the items i would lose is "Blackberry APN access". Will this have a negative impact on me in anyway or is this an old item that won't matter? Thanks in advance!
Older BlackBerry devices use a different way to connect to the Internet. If the plan you want has data included, then you're fine.
But I suggest you take the BlackBerry specific version of the plan you want anyway and here is why: if something should happen to your Q5 you'll still want to use your older BlackBerry while your Q5 is in the shop. The BlackBerry specific version of your plan will still play fine with your new Q5 as well as your older BlackBerry.
