picture messaging problem
i have bb 9900, got it unlocked and now im using koodo sim. I have picture messaging in my plan but cannot send it. doesn't even get attach option in my text but when I try my sim in some other phone it atleast lets me attach picture but never delivers the text. it always shows error and doesn't send.
Did you choose the BlackBerry specific version of your plan? BlackBerry prior to BlackBerry 10 devices require special provisions so they can access the BlackBerry Internet Service (BIS). These provisions are only active of your plan allows it. Check selfserve for the name of your plan. I'd it doesn't say (BB) at the end of it, you won't be able to send or receive mms (picture messages) . If not just change your plan to the BlackBerry version right there in self serve. If you do have a BlackBerry version of your plan, you may just need to update your service books. From your Blackberry, go to Options, select Advanced Options, select Host Routing Table, press the Menu button, select Register Now. You will shortly receive a confirmation message on your device.
Chad Burr wrote:
Did you choose the BlackBerry specific version of your plan? BlackBerry prior to BlackBerry 1...
how do u change it to bb version? and when should i receive a confirmation message?
Log into self serve, choose the "plan" tab. Click change plan. There's a list of devices, click it until you see the older style BlackBerry plans.
i dont see the plan i have in the list
Another possible need after you do what Chad suggested if things still don't work make sure you put in the Koodo APN settings. http://koodomobile.com/en/ab/non-koodo-phone-data-setup.shtml
Userlevel 2
Jorden wrote:
Another possible need after you do what Chad suggested if things still don't work make sure you p...
I don't believe Blackberries have the ability to customize the APN. On older Blackberries, registering the Host Routing Table programs the APN into the phone.
Perfect! Always good to learn something new 🙂. Thanks Myke!
Userlevel 3
Hi Ridze, Are you still having the same issues? Please keep us posted. ________________________ If you see a good answer, give it a star.
